How to disable wireless controller feature on Cisco 3850 Switch
abhisar patil
Dear Team,
I want to disable wireless feature on Cisco 3850 Switch. This is because we are facing Symantec backup issue on Cisco 3850 switch and its working fine on Cisco 3750.
Please suggest.
Thank You,
Abhisar.
stephendrkw
Level 3
Level 3
Can you please send me the following output:
sh run | i wireless
you should be able to disable using:
conf t
no wireless mobility controller
