Increasing Total output drops in the Cisco switch
dhinesh_83
Hi Team,
       I am seeing a total output drops are increasing in the switch side interface where the interface connected between router and switch.  I cleared the counters but still it increasing high.
Router Model: Cisco 3845
Switch Model : Cisco C3750
What could be the problem.?
What i need do further?
It will affect the network performance?
Please anyone provide the permanent solution to avoid this issue.
11 Replies 11
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
First question:  Generally, the problem is sending packets faster to the interface than it can transmit them.
Third question:  It might.
Second question:  Well, first you want to determine if it's adverse to your traffic needs.  If it is, you work to mitigate it.  How that would be done, depends on many factors.  For example, on your 3750, egress buffer tuning might mitigate.
Hi Joesph,
     Thank you for your response.When i ping from outside upto router i can get a normal response but i am seeing some latency to the devices beyond to the core-switch.
Is this network latency due to the output drops?
Can i go and change the cable between router and switch?
Any additional configuration is required in the switch to avoid this issue?
Core_Switch#sh running-config int gi1/1/1
Building configuration...
Current configuration : 135 bytes
interface GigabitEthernet1/1/1
 switchport access vlan 32
 switchport mode access
 speed 100
 duplex full
end
Core_Switch#sh int gi1/1/1
GigabitEthernet1/1/1 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is a44c.1125.378d (bia a44c.1125.378d)
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
     reliability 255/255, txload 10/255, rxload 7/255
  Keepalive not set
  Full-duplex, 100Mb/s, link type is auto, media type is 10/100/1000BaseTX SFP
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:25, output 00:00:00, output hang never
  Last clearing of "show interface" counters 05:23:04
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 17681
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 3070000 bits/sec, 1155 packets/sec
  5 minute output rate 3959000 bits/sec, 706 packets/sec
     22809172 packets input, 8884818718 bytes, 0 no buffer
     Received 16000 broadcasts (4547 multicasts)
     0 watchdog, 4547 multicast, 0 pause input
     14189775 packets output, 9303603992 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Disclaimer
Posting
The additional latency you're seeing, pinging past your router, might be congestion (although queues need to be somewhat deep at 100 Mbps).
Although you have drops, they are down in the .1% range, which is normally not adverse.
I agree with Joseph. Less than 1% output drops should not be harmful to your network.
In my case, I did not even notice there were any output drops on my network until we deployed Solarwinds. I fought with this for months trying to eliminate these output drops that always occurred on trunk links or switch to router links. In the end, I just removed the Solarwinds alerts for these interfaces.
I can't seem to find the document now, but I remember reading a Cisco document describing how total output drops less than 1% of the total packet output was considered normal behavior. If I find it I will re-post it here.
Hello everybody,
I would like to know which reference do you take for total packets count to get the percentage of total drops.
In my case to see total output drops, I look:
gh inter gi1/0/x stats
Switch model is 2960X or 3750G
SH INTER gi1/0/19 stats
GigabitEthernet1/0/19
          Switching path    Pkts In   Chars In   Pkts Out  Chars Out
               Processor          0          0     592191   49119124
             Route cache          0          0          0          0
                   Total          0          0     592191   49119124
I take as total pkts output 592191 but I don`t know if this is right.
Do you know if there is another better command to get this? And command:
sh inter gi1/0/19 counters
has to do anything with this?
In my case the output seems not to show output packets:
Port            InOctets    InUcastPkts    InMcastPkts    InBcastPkts
Gi1/0/19       283723984        1703350           2038           3303
Port           OutOctets   OutUcastPkts   OutMcastPkts   OutBcastPkts
Gi1/0/19      3913234602        2816627        1776580        1014199
Thank you everybody!!!
Disclaimer
Posting
I normally just look at the show interface counters, e.g.:
Good morning Joseph,
Ok, so you just take this command to get total packets. It is true it has this information, and to be true, I had not seen it!!
Thank you very much and if somebody could tell me if in output:
             Route cache          0          0          0          0
all the packets in processor mean there is no fast-switching in this switch. I have not disabled anything about this in this switch and I do not know why all interfaces give this result (2960X). I supposed ip route-cache was enabled by default in any switch.
Thank you!!
Disclaimer
Posting
Some of the switches don't always update all the "buckets" you would think they should.  The processor switching stats might only count software forwarded packets, which might not exclude CEF switching.
On a 2960X the bulk of your packet switching should be at the ASIC level.
Ok Joseph,
Thank you very much for your help!
Only one question more, why the bulk of packet switching should be at the ASIC level on this switch? If I see a 3750G it is the same.
When the CAM is created and goes filling up, I supposed the bulk of the switching would be through fast-switching rather than SW mechanism.
Thank you again!!!
Disclaimer
Posting
Yes, the bulk, ideally all, switching should be at the ASIC level.  Why?  Well because ASICs provide hardware switching which is what provides their high performance.
If the TCAM fills up, then you have CPU switching, which is much, much slower.  This can be avoided, on some switches, by using different TCAM profiles.  The 3750G calls them SDM.
Ok, Joseph. Thank you very much. Now I understand a bit better all this.
