10-03-2021 11:03 PM
i have an known below mentioned issue in my network. we have nexus 9k is our core and we have all SVI in it.
swith model : N9K-C9508
OS : NXOS: version 7.0(3)I7(6)
Can any share the command to configure IP device tracking in nexus environment and particularly equal nexus command for
"ip device tracking probe use-svi" ?
Thank you.
10-04-2021 12:10 AM
the command does not seem to be available on the N9K platform. On the N7K it works, not sure why they removed it...
10-04-2021 12:13 AM
I do not believe you have that feature in Nexus as per i know, is the Duplicate IP on SVI or End device ?
10-04-2021 12:21 AM
Thank you for your response.
The issue is with end point (VM server) .it is getting APIPA ip after restart.
10-04-2021 02:20 AM
Most DC Environemtn the IP pre-assigned to device, but if you lookling for DHCP for the VM, you need to give more information ?
Do you have IP helper oin SVI ? is this vPC ? - give more information about environment. any device working ? or only this device having issue ?
10-04-2021 03:24 AM
Yes you are correct.
We have pre assigned IP in servers.we don't want DHCP for this SVI. this issue is occurring only with vm server some time only and not all the time we restart.
yes we have ip helper on this SVI and i removed the IP helper command from SVI now.
yes this servers are working through vPC.
Thank you.
10-04-2021 03:56 AM
I do not believe this is nexus side issue for now as per the explanation, this is more VM or Windows Server side. (seen some time back on Windows 2012R2 servers, the subnet changes automatically, we need to manually put back the settings.)
