how to enable ip v6 for 3750/3560 switch?
Gongyuan Yao
We have 3750G and 3650G with IOS rel 12.2(50)SE3. According to Cisco document, these switches should support IP v4 and v6 dual-stack configuration (after 12.2SE). I have searched many Cisco IP v6 online help, but can not figure out how to enable this feature. Such as, I tried to configure an interface with IP v6 addr, but it will not take "ip v6" or "ipv6".  Any help would be great appreciated.
Thanks.
gy
2 Accepted Solutions
andtoth
Level 4
Level 4
First, you will need to change the SDM template to dual-ipv4-and-ipv6 with the sdm prefer dual-ipv4-and-ipv6 global configuration command. Please note that you will need to reload the switch in order for this change to take effect.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_50_se/configuration/guide/swsdm.html
Then you will need to enable IPv6 Routing with the ipv6 unicast-routing global configuration command.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_50_se/configuration/guide/swipv6.html
Best regards,
Andras
5 Replies 5
Reza Sharifi
Did you turn on "ipv6 routing" first?
Thanks.
It does not take the "ipv6 routing" cmd.
See the screen capture:
Switch Ports Model              SW Version            SW Image
*    1 28    WS-C3560G-24TS     12.2(50)SE3           C3560-IPBASEK9-M
Configuration register is 0xF
Switch#ipv?
% Unrecognized command
Switch#ip?
ip
Switch#config t
Enter configuration commands, one per line.  End with CNTL/Z.
Switch(config)#ip?
ip
Switch(config)#ip
Thanks.
gy
For IPv6 support you must enable the correct sdm template
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_25_see/configuration/guide/swsdm.html
Regards.
Alain.
andtoth
Level 4
Level 4
Best regards,
Andras
Thanks a lot for all of you people's help.
It works.
gy
