How to enable SSH on 4507R+E
I'm just setting up two 4507R+E but I can't configure SSH for remote control.
crypto command do not work as ip ssh etc.
Could you help me please ?
Olivier
Mark Malone
what image are you on , you need a K9 image for ssh/crypto services ?
please post the show ver
Mark Malone
As Mark notes, likely you don't have a crypto image.
Once you do, crypto command should take. When it does, you're probably want to enable SSH v2 and insure the crypto modulus size is 4K or better. Once you have SSH access working, you might also consider disabling telnet access.
