How to enable WS-C4507R-E web management
ryanhoibm
Hi all,
Does anyone know how to enable WS-C4507R-E web management?
Usually I will download .Tar image which has html file on it and I will configure the ip http path to point to it. I will also configure ip http server, authentication local....etc and Thats it!
But as for C4507R-E, I can;t find .tar image file.
So how can I enable web management on a C4506???
Thanks in advance
Ryan
Ryan
As far as i know the 4500 like the 6500 doesn't support the same setup as the 3560/3750 switches ie. you don't get a .tar file which expands into a directory for the 4500/6500.
You can use Cisco Network Assistant to configure the 4500. You will need to download the software for this separately as it doesn't come bundled with the IOS. Attached is a link to configuring CNA for the 4500 -
http://www.ciscosystems.com/en/US/docs/switches/lan/catalyst4500/12.2/25ewa/configuration/guide/netasist.html
You can download Network Assistant, which is free, from this link (note this link is also at the start of the doc above)  -
CNA
Jon
ryanhoibm
Hi All,
Anyone has any idea on how to enable and access C4507 web console??
Ryan
Ryan
CNA
Jon
Hi Jon,
You are absoutely correct!!! Thanks alot!! I just tried CNA yesterday... it worked fine.
Thanks very much!!!
Ryan Ho
