How to export _> flow.sampling_interval ?
ty.chan007
I am using Cisco ASR 1K .
I am trying to find how to export "flow.sampling_interval" value to collector in ELK.
please help.
on the ASR, I think you need to configure Netflow version 8, which has the sample interval field in the header.
--> ip flow-export version 8
The corresponding field in your elastiflow config would be:
"[netflow][sampling_interval]" => "[flow][sampling_interval]"
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/netflow/configuration/xe-3s/asr1000/nf-xe-3s-asr1000-book/cfg-nflow-data-expt-xe.html#GUID-3D1F5B64-E9E5-4433-98AE-BDBF5B259BF5
https://github.com/robcowart/elastiflow/blob/master/logstash/elastiflow/conf.d/20_filter_20_netflow.logstash.conf
There is no option to select version 8.
Available options are:
ipfix IPFIX (Version 10)
netflow-v5 NetFlow Version 5
netflow-v9 NetFlow Version 9
any suggestion ?
you have to configure an aggregation cache. Th examples below are an excerpt from the document linked...
configure terminal
ip flow-aggregation cache as
export destination 10.42.42.2 9991
export destination 10.42.41.1 9991
export version 8
enabled
interface Fastethernet0/0/0
ip flow ingress
configure terminal
ip flow-aggregation cache source-prefix
mask source minimum 30
enabled
ip flow ingress
end
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/netflow/configuration/xe-3s/asr1000/nf-xe-3s-asr1000-book.pdf
-##the version that I am using does not support those config anymore. I
have to use flow monitor command. So there is no option to netflow version
beside ipfix, v9 or v5.
