N7k Transceiver Receive power sensor alert
Hassan Chalabi
 HI,
I am getting some weird alerts from solarwinds, any one has an explanation?
ALERT NAME MESSAGE TRIGGERING OBJECT ACTIVE TIME RELATED NODE
 Hardware component is in warning or critical state Hardware component is in warning or critical state Ethernet3/3 Lane 1 Transceiver Receive Power Sensor
Ethernet3/3 is down (Link not connected)
admin state is up, Dedicated Interface
  Hardware: 1000/10000 Ethernet, address: 5087.8944.c4be (bia 5087.8944.c4be)
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec
  Encapsulation ARPA, medium is broadcast
  Port mode is fex-fabric
  auto-duplex, auto-speed, media type is 10G
  Beacon is turned off
  Auto-Negotiation is turned on
  Input flow-control is off, output flow-control is off
  Auto-mdix is turned on
  Rate mode is dedicated
  Switchport monitor is off
  EtherType is 0x8100
  EEE (efficient-ethernet) : n/a
  Last link flapped 00:03:53
  Last clearing of "show interface" counters 10w5d
  0 interface resets
  Load-Interval #1: 30 seconds
    30 seconds input rate 0 bits/sec, 0 packets/sec
    30 seconds output rate 0 bits/sec, 0 packets/sec
    input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
  Load-Interval #2: 5 minute (300 seconds)
    300 seconds input rate 56 bits/sec, 0 packets/sec
    300 seconds output rate 0 bits/sec, 0 packets/sec
    input rate 56 bps, 0 pps; output rate 0 bps, 0 pps
  RX
    108892 unicast packets  0 multicast packets  0 broadcast packets
    0 input packets  2496 bytes
    0 jumbo packets  0 storm suppression packets
    0 runts  0 giants  0 CRC/FCS  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    0 output packets  0 bytes
    0 jumbo packets
    0 output error  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble  0 output discard
    0 Tx pause
N7004-DC# show int e3/3 transceiver details
Ethernet3/3
    transceiver is present
    type is Fabric Extender Transceiver
    name is CISCO-JDSU
    part number is PLRXPL-VC-S43-CG
    revision is B
    serial number is JUR18520GK3
    nominal bitrate is 10300 MBit/sec
    Link length supported for 62.5/125um fiber is 10 m
    Link length supported for 50/125um OM3 fiber is 100 m
    cisco id is --
    cisco extended id number is 4
    cisco part number is 10-2566-02
    cisco product id is FET-10G
    cisco vendor id is V02
    number of lanes 1
           SFP Detail Diagnostics Information (internal calibration)
                Current              Alarms                  Warnings
                Measurement     High        Low         High          Low
  Temperature   35.39 C        75.00 C      5.00 C     70.00 C       10.00 C
  Voltage        3.31 V         3.63 V      2.97 V      3.46 V        3.13 V
  Current        6.24 mA       10.00 mA     2.59 mA     8.50 mA       3.00 mA
  Tx Power      -2.15 dBm       2.69 dBm  -11.30 dBm   -1.30 dBm     -7.30 dBm
  Rx Power     -30.00 dBm --    2.99 dBm  -13.90 dBm   -1.00 dBm     -9.90 dBm
  Transmit Fault Count = 0
  Note: ++  high-alarm; +  high-warning; --  low-alarm; -  low-warning
Reza Sharifi
Is this link connected to a FEX using a FET?
If you are getting false positive alerts, most of the time it is a Cisco bug and no much NPM.
