How to factory reset Catalyst C9200L-24T without command
Steven X
I bought a Catalyst C9200L-24T for backup two years ago and want to use it now, but I failed access it with webui account and password is neither cisco or S/N. I need to factory reset it. I had tried hold Mode button over 10 seconds, but the led doesn't flash then solid as some documents claims. Did I going the wrong way? Please reply me the correct way to reset. Thank you for any advice.
@Steven X wrote:
Sorry, I can't connect to console, I don't have console cable right now.
Look at the front of the switch.  There is a USB mini-Type B.  That is a console port.  There is no need to buy a dedicated Cisco concole cable when a USB Type A to a USB mini-Type B will suffice.
Password recovery process for the Catalyst 9200/9300 are different.
Power up the switch and observe the LED.  Do NOT press the Mode button.
Once the System LED starts to flash, press the Mode button 3 times in quick succession.  Remember, PRESS.  I did not say "hold it down".
does the console display anything, and if, what ?
Leo Laohoo
Please read the Catalyst 9200 Data Sheet very well -- It will be financially beneficial.
1.  All Cisco 9200/9200L comes with Cisco Enhance Limited Lifetime Hardware Warranty with every purchase of each switch.  (No need to be SmartNet to RMA the switch.)  Read the T&C, understand and know what rights and benefits you get.
2.  Each Cisco Catalyst 9200, 9300, 9400, 9500 and 9600 switches have free minor/major software download: Cisco Catalyst IOS Software Update Program for Cisco Catalyst 9200, 9300, 9400, 9500 and 9600 Series switches.  Please note the following:
●      Free critical updates:
◦    Free critical updates are available to the original customer for up to 1 year after announced end-of-support. These critical updates maintain the compliance of the Software with published specifications, release notes and industry wide compliance.
◦    Free vulnerability and security updates are available to the original customer for up to 3 years after announced end-of-sale.
◦    No support contract is required to obtain these software updates.
●      Free major and minor releases:
◦    Free major and minor release updates are available to an original customer moving from one release to another within the same perpetual license level (i.e. Cisco Network Advantage or Cisco Network Essentials).
◦    No support contract is required to obtain these releases.
Read it.  Understand it.
