How to filter a VLAN on NEXUS monitor session
rob.hicks1
Hi, I need to packet capture all traffic for a specific vlan configured on an etherchannel trunk interface (on a NEXUS 5548). A local span was successfully configured, however there appears to be no option to filter a specific vlan for the monitor session and therefore all traffic is being captured. Online documentation seems to suggest there is a way to filter a vlan - however i cannot see the option on the CLI (i am unsure if the filtering applies only to remote span, and not local span). Anyone know of a way to filter vlans for a monitor session, or know a work-around? I am currently capturing the whole VLAN which is not really what i wanted (and may also forward too much traffic) Many thanks current config is simply :- monitor session 1 source vlan 123 destination interface Ethernet1/1 no shut
Rajeev Sharma
Hey Rob,
Let us know what command is not accepted by system or where are you stuck?
I am adding a document for configuring SPAN and how to filter:
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/6_x/nx-os/system_management/configuration/guide/sm_nx_os_cg/sm_14span.html#pgfId-1313073
HTH.
RS
HI,
Thanks for the reply.
Below is an output from the CLI menu (within the monitor session sub menu) - as u can see there is no filter vlan option.  I cannot see anywhere else to add a filter option for an etherchannel trunk interface?
At the moment the monitor session is currently set to monitor the whole vlan123, however i want to monitor only vlan 123 on a specific etherchannel trunk interface.
Rob
Nexus5548
version 5.2(1)N1(1b)
sw_hostname(config-monitor)# ?
  description  Session description (max 32 characters)
  destination  Destination configuration
  mtu          Set the MTU size for SPAN packets
  no           Negate a command or set its defaults
  shut         Shut a monitor session
  source       Source configuration
  end          Go to exec mode
  exit         Exit from command interpreter
  pop          Pop mode from stack or restore from name
  push         Push current mode to stack or save it under name
  where        Shows the cli context you are in
sw_hostname# show monitor session all
   session 1
type              : local
state             : up
source intf       :
    rx            :
    tx            :
    both          :
source VLANs      :
    rx            : 123
source VSANs      :
    rx            :
destination ports : Eth1/1
Legend: f = forwarding enabled, l = learning enabled
Hey Rob,
Unfortunately on Nexus5K traffic filtering options are very limited but an enhancement is already filed .And then it will allow to configure VACL for filtering, please have a look:
https://tools.cisco.com/bugsearch/bug/CSCtu14210
HTH.
RS.
Not quite the answer i was hoping for, but many thanks for taking the time to confirm the situation.
Guess it looks like i need to wait for a code update :(
Thanks again,
Rob
