HOW to filter EIGRP with ACL
Hello;
I have this configuration in my network.i want to implement filtering with ACL in EIGRP.
This is my config
HQ
router eigrp 226
network 10.10.250.8 0.0.0.7
network 172.16.32.0 0.0.0.255
redistribute static
neighbor x.y.32.253 GigabitEthernet0/0/0
neighbor x.y.32.252 GigabitEthernet0/0/0
neighbor x.y.32.251 GigabitEthernet0/0/0
  eigrp log-event-type dual xmit
spoke1
router eigrp 226
network w.q.8.0 0.0.0.63
network w.q.8.64 0.0.0.31
network w.q.8.96 0.0.0.7
network w.q.8.128 0.0.0.127
network x.y.32.0 0.0.0.255
network 192.168.254.0 0.0.0.7
redistribute static
neighbor x.y.32.254 GigabitEthernet0/0/0
spoke2
router eigrp 226
network w.q.9.0 0.0.0.63
network w.q.9.64 0.0.0.31
network w.q.9.96 0.0.0.7
network w.q.9.128 0.0.0.127
redistribute static
spoke3
router eigrp 226
network w.q.10.0 0.0.0.63
network w.q.10.64 0.0.0.31
network w.q.10.96 0.0.0.7
network w.q.10.128 0.0.0.127
redistribute static
Someone knows how to do?
10 Replies 10
filter what exactly ?
in my case i have a certification recommandation that oblige me to apply an ACL to filter EIRGP routes.I want to put this ACL without any changes.
You can try this:
http://technologyordie.com/eigrp-route-filtering-with-acls
-David
@David Ruess in my case the distribue list must be in or out on my interface gigabitethernet 0/0/0?
If you just have the in/out keyword with NO interface after then it filters the route specified in the ACL form all interfaces in or out. If you have an interface configured with it, it will only filter routers coming/going form that specific interface. So its whatever your requirement is.
-David
Hello;
can i only use distribute out on the differents interfaces(that joined HQ) on spokes and also use distribute out in the interface (who joigned neihbors) ?
you are not inform us what you want to filter, which prefix ?
I see that many neighbors is reachable via same interface so please config this ?
I want to just apply a permit ACL to eirgp.Just to be conform to certification
Lab,
the issue with of Filter prefix in your case is the Hub-Spoke design,
I do more than one lab and failed to filter the prefix in Hub why ? because the Hub use same interface for all neighbours, and I make fast check the EIGRP don't have per-nieghbor prefix filter.
so I go to other solution
in my lab the R3 advertise two prefix 3.3.3.3/32 and 33.33.33.33/32
I config distribute-list with direction IN in Spoke R2 to filter what it can get from Hub+Spoke R3
this deny 33.33.33.33 and allow all other prefix.
hostname R1
interface FastEthernet0/0
ip address 100.0.0.1 255.255.255.0
no ip next-hop-self eigrp 100
no ip split-horizon eigrp 100
duplex half
router eigrp 100
network 100.0.0.0 0.0.0.255
neighbor 100.0.0.2 FastEthernet0/0
neighbor 100.0.0.3 FastEthernet0/0
hostname R3
interface Loopback0
ip address 3.3.3.3 255.255.255.255
interface Loopback10
ip address 33.33.33.33 255.255.255.255
ip address 100.0.0.3 255.255.255.0
duplex half
router eigrp 100
network 3.3.3.3 0.0.0.0
network 33.33.33.33 0.0.0.0
neighbor 100.0.0.1 FastEthernet0/0
hostname R2
ip address 100.0.0.2 255.255.255.0
duplex half
router eigrp 100
distribute-list prefix 33.33.33.33 in FastEthernet0/0
ip prefix-list 33.33.33.33 seq 10 deny 33.33.33.33/32
ip prefix-list 33.33.33.33 seq 20 permit 0.0.0.0/0 le 32
