how to find Internal Functioning of two switches ?
babashaheer
Please c the following figure :
Here all are new devices. No CDP. client 1 should communicate with client 2.
so how the process will start. ( internal functioning )
Why and how arp will generate ?
how two switches will communicate internally. ( i mean how the headers will function).
saif musa
Level 4
Level 4
Install wireshark on one of  the PCs above, it will allows you to chick in details whats happening in realtime.
https://www.wireshark.org/
PLease rate if its helpful
saif musa
Level 4
Level 4
Yaa i will try that. Thank u said musa :)
benford01
What subnet mask do you have set on each of the endpoints ?
My guess is they do not communicate with each other since they are on different subnets and you will need a router between the switches unless you are doing VLAN routing.
Ben
Got u. Thanks a ton.. benford01 :)
