How to find the port of switch base on ip address
zhendongzhang
Hi,All,
Do you someone may give me some guide on how to relocate the port of switch base on I know ip address?Actually this is important when I knew someone computer send out lots of traffic.
bjw
Level 4
Level 4
If you know the IP address of the suspected device;
1. Go to the default gateway (router/L3 Switch) and do a Show arp with the known IP address.
2. Arp should come back with the MAC address associated with the known IP address.
3. On the subject switch, do a show mac-address (IOS), or show cam static (CatoS). The output of these commands will show you the MAC address and Port/Interface# where that MAC address is being seen.
Jon Marshall
You don't say whether the switch is layer 2 or layer 3 and whether it is IOS or CatOS.
Assuming IOS.
On the layer 3 device, whether that is the switch itself or a router,
1) show arp | include "ip address" eg
NW-MSQ1-F02-CS1#sh arp | include 10.180.172.34
Internet 10.180.172.34 64 000e.d797.1a7f ARPA FastEthernet2/1
2) On the switch
sh mac-address-table address 000e.d797.1a7f
This will give you the port that the switch has registered this mac address against.
Jon
Thanks all,I knew now.Thanks you. Here is my step for get port on htat switch.
1.查找高流量的IP 地址
sh ip cache flow
2.根据IP 地址查switch 上的端口
sALCNshg01#ping 10.35.3.43
Sending 5, 100-byte ICMP Echos to 10.35.3.43, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/202/1004 ms
sALCNshg01#show arp | include 10.35.3.43
Internet 10.35.3.43 0 0011.85ea.2e2d ARPA VLAN100
sALCNshg01#show mac address 0011.85ea.2e2d
Non-static Address Table:
Destination Address Address Type VLAN Destination Port
0011.85ea.2e2d Dynamic 100 FastEthernet0/41
