How to fix a 2960x with formatted flash? Is it dead?
I picked up a second hand 2960x on ebay with a formatted flash.  I can connect to it.  I have tried the following:
a.  Copy the IOS to a flashdrive, copy to flash and try to boot from there.
b. Try to boot directly from the usbflash.
In both cases the image verifies, passes digital signature verification reports it is uncompressed and installed, says it is loading but just sits there.  (Output below and attached.)  Is there anything I can do to resolve this?  thanks
All help much appreciated.
David
CPU rev: B
Image passed digital signature verification
Board rev: 5
Testing DataBus...
Testing AddressBus...
Testing Memory from 0x00000000 to 0x1fffffff.../
Using driver version 4 for media type 1
Xmodem file system is available.
Base ethernet MAC Address: 0c:f5:a4:8c:e3:00
The password-recovery mechanism is enabled.
USB EHCI 1.00
USB EHCI 1.00
USB Console INIT
Initializing Flash...
mifs[5]: 10 files, 1 directories
mifs[5]: Total bytes : 1806336
mifs[5]: Bytes used : 690688
mifs[5]: Bytes available : 1115648
mifs[5]: mifs fsck took 1 seconds.
mifs[6]: 1 files, 1 directories
mifs[6]: Total bytes : 3870720
mifs[6]: Bytes used : 971264
mifs[6]: Bytes available : 2899456
mifs[6]: mifs fsck took 0 seconds.
mifs[7]: 5 files, 1 directories
mifs[7]: Total bytes : 258048
mifs[7]: Bytes used : 8192
mifs[7]: Bytes available : 249856
mifs[7]: mifs fsck took 1 seconds.
mifs[8]: 5 files, 1 directories
mifs[8]: Total bytes : 258048
mifs[8]: Bytes used : 8192
mifs[8]: Bytes available : 249856
mifs[8]: mifs fsck took 0 seconds.
mifs[9]: 1 files, 1 directories
mifs[9]: Total bytes : 122185728
mifs[9]: Bytes used : 26930688
mifs[9]: Bytes available : 95255040
mifs[9]: mifs fsck took 32 seconds.
...done Initializing Flash.
Loading "flash:c2960x-universalk9-mz.152-7.E3.bin"...Verifying image flash:c2960 x-universalk9-mz.152-7.E3.bin................................................... ................................................................................ ................................................................................ ................................................................................ ................................................................................ .....................................Image passed digital signature verification
File "flash:c2960x-universalk9-mz.152-7.E3.bin" uncompressed and installed, entr y point: 0x3000
executing...
Loading "flash:/c2960x-universalk9-mErr: Interrupt: Critical input (0x100).
PC: 0x3f5e07fc, MSR: 0x00000000, ESR: 0x00000000,
(Bailed out.)
Err: Interrupt: Instruction TLB miss (0
CPU rev: B
Board rev: 5
Testing DataBus...
USB EHCI 1.00
USB EHCI 1.00
USB Console INIT
mifs[9]: filesystem check interrupted!
The system has been interrupted, or encountered an error
during initialization of the flash filesystem. The following
commands will initialize the flash filesystem, and finish
loading the operating system software:
flash_init
boot
switch: flash_init
mifs[9]: mifs fsck took 30 seconds.
switch: dir
List of filesystems currently registered:
bs[1]: (read-only)
flash[9]: (read-write)
xmodem[10]: (read-only)
null[11]: (read-write)
usbflash0[12]: (read-write)
tftp[13]: (read-only)
switch: dir usbflash0:
Directory of usbflash0:/
4 -rw- 26714112 <date> c2960x-universalk9-mz.152-7.E3.bin
225524K bytes available (26100K bytes used)
switch:
switch: set boot usbflash0:c2960x-universalk9-mz.152-7.E3.bin
switch: boot
Loading "flash:c2960x-universalk9-mz.152-7.E3.bin"...Verifying image flash:c2960x-universalk9-mz.15 2-7.E3.bin......................................................................................... ................................................................................................... ................................................................................................... ................................................................................................... ......................Image passed digital signature verification
File "flash:c2960x-universalk9-mz.152-7.E3.bin" uncompressed and installed, entry point: 0x3000
executing...
Loading "flash:/c2960x-universalk9-mz.152-7.E3.bin"...
balaji.bandi
Advise to download different Lower version and try c2960x-universalk9-mz.152-4.E7.bin
BB
balaji.bandi
BB
Thank you that worked.  Am now back up and running!  Most grateful!
balaji.bandi
Glad all good now...start labbing learn more.
BB
