Replacement for WS-C2924-XL-EN
Hello Community,
Could you suggest the best compatible model for a WS-C2924-XL-EN which needs to be replaced?
Thank you.
balaji.bandi
Depends on budged.
Cat 1000, For better version only layer 2 with Limited Layer 2 Cat 9200
Full blown features you looking then Cat 9300 for Longer upgrade path.
BB
marce1000
 - You can also start from here :
                 https://www.cisco.com/c/en/us/products/switches/switch-selector.html
 M.
Leo Laohoo
Depends entirely on your budget:
  1. Catalyst 1000 if finances are tight
  2. Catalyst 9200 if you do not want SD-Access
  3. Catalyst 9300 SD-Access support
