How to identify Cisco 2611XM Router
a.ajiboye
Hi All,
I bought a Cisco router which I belived to be a 2611XM router. Could someone tell me how to figure it out if this router is a 2611XM or not from the output of the "show ver" command?
What do I look out for in the show version command that would tell me that this router is a 2611XM?
Thank you.
glen.grant
Should say right in the show version that it is a 2611xm , if only says 2611 then its not a XM .
ajagadee
Below is the "show version" output from a 2611xm. I hope it helps.
2600#sh ver
IOS (tm) C2600 Software (C2600-IS-M), Version 12.2(40), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Thu 12-Oct-06 21:01 by pwade
Image text-base: 0x8000808C, data-base: 0x8111D524
ROM: System Bootstrap, Version 12.2(7r) [cmong 7r], RELEASE SOFTWARE (fc1)
chi-2600-8 uptime is 22 weeks, 1 day, 12 hours, 50 minutes
System returned to ROM by reload
System image file is "flash:c2600-is-mz.122-40.bin"
cisco 2611XM (MPC860P) processor (revision 0x100) with 93184K/5120K bytes of mem
ory.
M860 processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s)
2 Low-speed serial(sync/async) network interface(s)
32K bytes of non-volatile configuration memory.
49152K bytes of processor board System flash (Read/Write)
Arul
