how to implement uRPF when multiple WAN and LAN interfaces exists
mohammed hashim
hi,
in this topology:
R1 knows about 8.8.8.8 through both ISP-1 and ISP-2,
how to configure R1 to match the picture when spoof packets came from WAN, or LAN, these spoof packets should be denied, without affecting the redundancy
appreciate your help,
Philip D'Ath
The effectiveness of RPF on dual homed ISP connections is rather limited.  Assuming both ISPs also advertise a default route, you can probably use something like:
On the ISP interfaces you'll need to use something like:
ip verify unicast source reachable-via any allow-default
I personally wouldn't use RPF in this scenario due to the risk of something going wrong.
