12-04-2020 02:02 PM
How to integrate a Meraki firewall with Catalyst 3650 switches Configuration
while the Meraki FW gives out DHCP.
12-26-2020 04:19 AM - edited 12-28-2020 03:03 AM
Hello
First of all you need to register, claim then add the MX into the meraki dashboard within your created organization here
Then you create the L3 interfaces and DHCP scopes from Security & SD WAN directory
On the 3650 create the L2 vlans associated with the L3 vlans your create on the MX and for the switchport that's connects to the MX configure that as a trunk.
Lastly have a look at this previous post
12-28-2020 02:30 AM
Because wireless data traffic is visible at the Catalyst 3000 family switch, network managers can identify and assign priorities to wireless traffic with Cisco's Flexible NetFlow technology.
https://community.cisco.com/t5/switching/cisco-3560-config-pier-with-meraki-mx-firefall/td-p/4194017
