how to know if my bgp neighbour advertised my subnet or not ???
Dr.X
Level 7
Level 7
hi ,
i want to ask ,
how to know if my bgp neighbour advertised my network from his side or not ???
here is my config :
Gateway7600#sh ip bgp
BGP table version is 8, local router ID is 192.168.40.3
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
              x best-external, a additional-path, c RIB-compressed,
Origin codes: i - IGP, e - EGP, ? - incomplete
RPKI validation codes: V valid, I invalid, N Not found
     Network          Next Hop            Metric LocPrf Weight Path
r>  0.0.0.0          a.a.56.165           0             0 xxxx i
*>  x.x.64.0/23   10.160.150.1             0         xxxx i
*>  y.y.19.192/27  10.160.150.5             0         3xxxx i
Gateway7600#sh running-config  | s bgp
router bgp zzz
bgp log-neighbor-changes
network x.x.64.0 mask 255.255.254.0
network y.y.19.192 mask 255.255.255.224
neighbor a.a.56.165 remote-as aaaaa
Gateway7600#
Gateway7600#sh ip bgp neighbors a.a.56.165 advertised-routes
*>  x.x.64.0/23   10.160.150.1             0         32768 i
*>  y.y.19.192/27  10.160.150.5             0         32768 i
Total number of prefixes 2
note that the problem in the network
y.y.19.192/27   <======== only
the network
x.x.64.0/23
is ok and no problems .
my question is , how to know if the my neighbour advertised my network
y.y.19.192/27
to the internet or not ???
can i test it  from my local  router ???
i searched the  site :
http://service.dic.at/cgi-bin/lg.cgi
and my subnet /27 is not shown !!!!!!!!!!!
plz help
regards
5 Replies 5
Raju Sekharan
sh ip bgp neighbors a.a.56.165 advertised-routes is the right command to check
Normally /27 routes will get summarized at ISP level. So you should see your prefix with /24 prefix-length or smaller when you look at public route servers
The best way is to check to ping your IP reachability from internet
Also your immedaite ISP should be able to tell you if they have received your /27 advertisement
Thank you
Raju
hi
Raju
thanks for your reply
look, i have have two isps .
i would like to say that i advertised the network
y.y.16.0/22
but note i advertised it summarized  /22 but from another isp  and i set a specific attributes for the subnet /22
now i want to advertise only  /27  which is part of    /22    in another isp
the problem is   when i look for the subnet  /27 ips=========>
it only give me the bgp summary about /22   and not /27
i mean it is supposed to give me two results
one from /22 advertise
and  another one from /27 advertise
should i contact my isp  and ask him if he performed a summarization ???
regards
advertising any prefix with prefix-length between /25 to /32 normally get summarized in ISP level
It may be your immedaite ISP or an upstream service provider
You can check with your ISP to see if they are receving your routes and if they are doing summarization
Thank you
Raju
HI ,
Raju
for your precious info
i will contact my isp and ask him about this issue .
regards
You are welcome
Thank you
Raju
