How to Logging http login
TEAM_ADP_CDGBS
I am using Cisco 2960X version 15.2.
I configure http web server and client :
ip http server
ip http authentication aaa login-authentication XXXX
ip http authentication aaa exec-authorization XXXX
ip http secure-server
ip http max-connections 3
ip http timeout-policy idle 60 life 10 requests 120
I would like to logging the login authentication. I can't find anything how to do it ?
If someone could help me. Thanks you.
Ruben Cocheno
@TEAM_ADP_CDGBS
This is an example of logging your logins attempts
logging on
logging 192.168.1.1
login block-for 60 attempts 3 within 60
login on-failure log every 1
login on-success log every 1
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
balaji.bandi
how about enabling aaa acounting  start-stop logging ?
BB
Ruben Cocheno
@TEAM_ADP_CDGBS
logging on
logging 192.168.1.1
Thanks it's logging.
It is logging as long as the login session is running by http/https.
Is It possible to have less logging ?
