How to login to Switch?
I have enabled SSH and forgot to mention Login local comman vty. could you guys suggest me how to login to switch now?
I dont have console access?
Bilal Nawaz
Hello, have you got a copy of the running config?
If you had 'transport input all' under vty lines you could try telnet to the switch.
How did you enable ssh which steps did you take? It may be that we might have to reboot somehow, or getting console access if we cannot telnet or get in to the switch by other means.
Hope this helps
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
mahmoodmkl
Level 7
Level 7
Is this switch managed by snmp if yes try to upliad the cinfig using write community string by using solarwinds etc
If not u need to have console access
Sent from Cisco Technical Support Android App
Prasan Venky
Level 3
Level 3
Console is the best option to go with as of now...
