How to make 10.0.0.0/24 network communicates with 10.1.0.0/24?
kent05
Good day guys.
I have a homelab with following topology:
home router <----> cisco router <-----> cisco L3 switch <-----> ESXi host + vcenter in R710 server.
Home router = 10.0.0.1
Cisco router = 10.0.0.2 / 10.1.0.1
Cisco L3 switch = 10.1.0.2
ESXi = 10.0.0.5
vCenter = 10.0.0.6
 I installed two AD DCs (DNS + DHCP roles) with ip addresses 10.1.10.1 & 10.2 respectively to serve for my 3 nested ESXi hosts with ip addresses 10.1.20.10, 30.10 & 40.10, respectively.  I also installed vcenter on each of the nested ESXi hosts with ip addresses 10.1.20.11, .30.11 & 40.11, respectively.
I can access 10.0.0.0/24 network through 10.1.0.0/16 network but not the other way round. Do I need to configure ospf in both cisco L3 switch & router? If yes how do I go about?
10 Replies 10
M02@rt37
Hello @kent05
You say 10.0.0.0/16 that cover ADDC, venter and ESXi hosts... where is configured the Gw of that /16 subnet ?
Or, do you have subneted this /16 and have different vlan on your L3 switch...
You talk about ospf too... please more elaborate and post if possible diagramm of your topology.
Thanks.
Best regards
Hi M02@rt37
Below is my home lab's network topology.I configured different vlans in L3 switch. Basically what I'm trying to achieve is I want to group all nested ESXi hosts into cluster in vCenter 8 (10.0.0.6) but unfortunately the vCenter failed to contact all nested ESXi hosts. Only those nodes in 10.1.0.0 /16 subnets can reach 10.0.0.0/24 subnet.
Thanks @kent05
If I understand, the problem is that the home router (10.0.0.1) doesn’t know how to reach the 10.1.x.x VLAN networks sitting behind the Cisco router ?
So, add static route on the home router for the nested VLANs (10.1.0.0/16 or each /24) pointing to 10.0.0.2 or modify vcenter gw from 10.0.0.1 ->10.0.0.2 so all 10.1.x traffic is sent directly to the cisco router, which already know those subnets...
Best regards
M02@rt37
I have added 10.1.0.0/16 in the router but it is seem like doesn't work.
10.0.0.0 appear in your network twice
That not correct.
MHM
Hi @MHM Cisco World
Which part does 10.0.0.0 appear in my network twice?
VCenter have 10.0.0.0/24 and between home and router you use 10.0.0.1 and 10.0.0.2 !!!!
You need to change one of them
MHM
@MHM Cisco World
Why can't vCenter have same 10.0.0.0/24 subnet with home router and cisco router with 10.0.0.1 and 10.0.0.2?
In your network you can not have same subnet in two link
This make other l3 device confuse' forward 10.0.0.0 traffic to which device ?
Change vcenter subnet
Then
1- in L3SW run ip routing
2- in LSW use defualt route toward Cisco router
3- in cisco route use static route toward l3SW for each vlan connect to it
4- in cisco router use NAT'
Why NAT? I think you can not add route to home router so' home router only see Cisco router IP' behind this IP it dont known anything' so we NATing VLAN in Cisco router to IP reachable by home router.
MHM
Which subnet should I use? I have enabled ip routing in the switch. The default route is 0.0.0.0 0.0.0.0 10.1.0.1.
Cisco router's static route is 0.0.0.0 0.0.0.0 10.0.01 & 10.0.0.0 255.0.0.0 10.1.0.2. I also configured ACL & NAT.
