09-12-2025 01:05 AM
I have connected three Catalyst C1300-24T-4X to a stack. All switches run firmware 4.1.7.17 and they are working fine but as soon as I disconnect the switch with stack ID 1 from power the other two switches stop working and freeze.
Any idea or solution for a workaround?
09-12-2025 05:10 AM
- @daniel_h I would advise that you configure a syslog server on the stack first, when it is working normal.
When the issue happens, then check the last logs which arrived at the syslog server,
M.
09-12-2025 06:42 AM
09-13-2025 12:33 AM
Also look one of the stacking guide lines for ipv4 :
=====️ Preenayamo Vasudevam ️=====
09-12-2025 06:32 AM
Ring and chain stacking options, auto stacking port speed, flexible stacking port options
-> do you have a ring or chain configuration ?
if chain, -> what position in the chain is ID-1
when ID-1 is positioned in the middle of the chain ( 2-1-3), and is powered down then 2 and 3 cannot communicate with each other
09-12-2025 06:36 AM
I have changed the configuration for "Unit ID" from fixed to auto. Now it looks like a backup switch becomes active as soon as the active one fails.
I use ring configuration
