How to merge vty?
ThisIsLoai
Hello there,
while configuring vty I have chose vty 0 4 then vty 5 15 then vty 5 6.
Here's what I got in my config file:
line vty 0
password 7 083540
no login
transport input ssh
line vty 1 4
password 7 082D4342
no login
transport input ssh
line vty 5 6
password 7 082D4342
no login
transport input ssh
line vty 7 15
no login
transport input ssh
How to delete vty? or how to merge them together?
Leo Laohoo
conf t
 line vty 0 15
 password YIPEE!
end
9 Replies 9
Reza Sharifi
You can't delete the VTY lines.
I see
Leo Laohoo
conf t
 line vty 0 15
 password YIPEE!
end
Thanks, Leo.
what's the explanation?
Explanation is simple:  RTFM
I learnt that when I was studying CCNA.  It is the first set of "instructions" in books, courses and CBT.
lol, I DO READ the TFM. it's not mentioned!
I'v took CCNA1 & i'm studying CCNA2 on netacad.com
I have not come across those kind of configurations.
@ThisIsLoai wrote:
it's not mentioned!
Oh geez!  Seriously, they never mentioned this is netacad?  WTF.
Yes they mentioned it (general concept n how to configure it) but not the point i asked !!
cuz i try to get hands-on i get confused sometimes n start to wonder n to ask more questions like hows ,ifs, and buts.
It's not a guarantee, but once you "know" a bit about how commands in an environment work, if something isn't directly documented, try doing what appears "logical" within that environment.
In this case, for example, you already should know you can configure VTY either using a specific line number or a range of line numbers.  So, since you wanted to "merge" VTY lines 0 15, using a command using "VTY 0 15" might be part of "the trick", as also might (unsure it's supported for VTYs), something like "default VTY 0 15" before you further configure them.
