Power Supply for Cisco 3750x 48 p-s switch
mflores09
I have a question about power supply for a cisco 3750x 48 p-s switch.  I have bought a couple of switches from a vendor that sent some  3750x 48 p-s switch that came  with 715w and some with 1100w power supply.    Does the 3750x 48 p-s work with 1100w power supply?  From what i read they should only have 715w.  If they do work with 1100w power supply.  Will that provide the same POE power as the 3750x 48 pf-s switches?
Yeah it can.
  The power provided to the PoE port doen´st change but you can have more ports with PoE devices plugged when using C3KX-PWR-1100WAC
But keep in mind that it is 1100 WAC and not W.  The output power is actually 800W.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3560-x-series-switches/data_sheet_c78-584733.html
balaji.bandi
what is the full model, most of the model works with combination of PSU, until it was fixed like old 3750
BB
scrabblelives
There are 3 power supplies models for this series, larger 2 of which do PoE.
