How to monitor Cisco Hardware on solarwinds
pushpendra_y
Hi Team,
How to setup monitoring on Cisco Switches for hardware health check(like if fan fails, temp goes high) and then how to monitor it via solarwinds.
Please assit
Traian Bratescu
There is a built-in monitor... " Hardware Health Sensors"
You can choose which ones you one to be monitored:
UpFan
UpFan 1Normal
UpFan 2Normal
UpFan 3Normal
UpFan 4Normal
UpFan TrayNormal
UpPower Supply
Up1.2V voltage in mVNormal1.207 V
Up1.8V voltage in mVNormal1.83 V
Up12V voltage in mVNormal12.592 V
Up2.5V voltage in mVNormal2.505 V
Up3.3V voltage in mVNormal3.322 V
Up5V voltage in mVNormal5.173 V
UpASIC voltage in mVNormal1.049 V
UpC2921/C2951 AC-POE Power SupplyNormal
UpCPU Core voltage in mVNormal1.226 V
UpTemperature
UpCPUNormal58 °C
UpExhaust LeftNormal39 °C
UpExhaust RightNormal38 °C
UpIntake LeftNormal36 °C
UpIntake RightNormal34 °C
UpPower SupplyNormal47 °C
Traian
Patrick Callum
Hello
How I do it is by enabling SNMP on the device, in SW go to add node enter the hostname or IP choose Most Devices: SNMP and ICMP enter your strings click next and select the resources you wish to monitor, you can get very granular from the device health to your interfaces or even by layer.
