how to multicast or broadcast a packet ?
pranav2794
Is there any command in Linux/Unix or Windows by which I can broadcast a packet or multicast over a LAN or over a WAN ?
If yes do tell me in brief about them.
andrew.prince
Level 10
Level 10
You need an application to do that.
Jon Marshall
Depends exactly on what you are trying to do. For example you could send a ping to the broadcast or multicast address quite easily eg.
subnet = 192.168.5.0 255.255.255.0
from the linux/windows device - ping 192.168.5.255 would send a broadcast on the local network. But as Andrew says, if you need to do it from a specific app then it is up to the app to do that.
Jon
