How to nat between 2 interfaces
vidalgenel
Hello all,
I am using a 1941 cisco router and i have to prefom nat between two interfaces.
The first interface will allow only specific vlan and the other will nat all the rest of the network.
How can i acheive that?
2 Accepted Solutions
HI Vidal,
As per my understanding you are trying to use NAT for two separate Outside interfaces, probably links by two ISP's
Check this document:
https://supportforums.cisco.com/docs/DOC-8313
It has your scenario explained in terms of Nating. Basically what you need is to implement Policy Based NAT where a route-map will be applied on the "ip nat inside source" command which will match ACL as well as the outgoing interface.
Another useful link for this would be:
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080950834.shtml
Hope it helps
Neeraj
If I understand correctly, you want to NAT based on source from different IP's, to different interfaces? You could do this - as an example:
Your ACL's
ip access-list extended ACL_ANY
permit ip any any
ip access-list extended ACL_192
permit ip 192.168.30.0 0.0.0.255 any
deny ip any any
Your Policy Based Route-Maps
route-map PBR permit 10
match ip address ACL_192
set ip next-hop x.x.x.x
route-map PBR permit 20
match ip address ACL_ANY
set ip next-hop y.y.y.y
(doesnt have to be ip next-hop, can be interface exit point too)
Route-maps for your NAT statements
route-map NAT_192 permit 10
match interface XXXX
route-map NAT_ANY permit 10
match interface YYYY
(Interface will be where the next hop ip will live i.e. exit point)
Policy based routing on the inside interface
interface LOCAL
ip nat inside
ip policy route-map PBR
interface XXXX
ip nat outside
interface YYYY
ip nat outside
Your NAT statements
ip nat inside source route-map NAT_ANY interface YYYY overload
ip nat inside source route-map NAT_192 interface XXXX overload
I think this will do it...
I hope this helps.
Please rate useful posts and remember to mark any solved questions as answered. Thank you.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
5 Replies 5
Reza Sharifi
My problem is that i have to interfaces that i should nat to the internet, i want to route only one network to 1 interface
and all the other traffic to the other interface how can i do that?
The link you sent me didnt mention this case.
This is what i have configured:
ip nat inside source list MY-NAT-Acl interface Vlan999 overload
ip route 0.0.0.0 0.0.0.0 x.x.x.x
ip access-list extended MY-NAT-Acl
permit ip any any
access-list 100 permit ip 192.168.30.0 0.0.0.255 host 0.0.0.0
route-map Voip-Line permit 10
match ip address 100
set ip next-hop verify-availability
HI Vidal,
Hope it helps
Neeraj
Your ACL's
permit ip any any
deny ip any any
interface LOCAL
ip nat inside
interface XXXX
ip nat outside
interface YYYY
ip nat outside
Your NAT statements
I hope this helps.
E31qinhaijun
hi,
I have met this problem,According to the general situation ,config the nat on the two intfaces.The key is using
Extend ACL to control the packets how to go.
