how to prevent loop from unmanged switch connected to cisco 2960 switch
mahmoudmostafa
dears
can we prevent a loop from accrue unmanage switch connected to cisco 2960 port
Leo Laohoo
Yes you can.
Enable BPDU Guard (and disable error-disable recovery) and allow a maximum of 3 MAC address per interface.
Leo Laohoo
Yes you can.
thanks alot for your reply
i will check and feed you back
Dear Leo
Its working Fine thank you
This discussion has been reposted to the  LAN, Switching and Routing community.
