How to properly upgrade a SG550XG-8F8T
Joshi
Greetings,
I have a cluster, consisting of two SG550XG-8F8T. I need to update the firmware (got told so by Cisco support after an outage). Since I have never done this before, I am curious what the best way to accomplish this would be?
Thanks in advance
Joshi
Mark Malone
Hi see this link shows you the options you have to upgrade, you will need a CCO account to download the software , USB probably the easiest method , put firmware on it load it up and reboot
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/350xg/admin_guide/AG_Tesla_350_550.pdf
The following methods for transferring files are supported: •HTTP/HTTPS that uses the facilities provided by the browser•USB•TFTP that requires a TFTP server •Secure Copy Protocol (SCP) that requires an SCP server
