How to Push internet traffic for a VLAN to a specific Gateway and the other Vlans to another Gateway
Hello
I currently have the following VLANs on my 3560 Switch with IP Routing Enabled. All VLANs can and need to communicate with each other
What i want to do is have all my VLANS route internet based traffic to our CISCO PIX IP-10.10.1.101 which is on Vlan 111 except for traffic on VLAN 11 which i want internet traffic to route to our new SonicWall NSA 3600 with IP 10.10.1.100.  Currently all traffic that is not interVLAN communication is routed to our PIX as you can see by the routes i have entered on our 3560.  How do i push traffic on VLAN 11 to the Sonicwall?
Thank You in advance for your help.
VLAN Name
1    default
10   VM_Servers      Interface IP - 10.10.10.1
11   TEST_VLAN     Interface IP - 11.11.11.1
111  Server             Interface IP 10.10.1.111
120  IT                    Interface IP - 10.10.120.1
130  Integ               Interface IP 10.10.130.1
140  Office              Interface IP - 10.10.140.1
150  ENG_Plant      Interface IP - 10.10.150.1
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.1.101
ip route 10.10.2.0 255.255.255.0 10.10.1.101        "User VPN Subnet"
ip route 10.10.6.0 255.255.255.0 10.10.1.101        "L2L VPN Tunnel between off site ASA Device and PIX"
ip route 10.10.7.0 255.255.255.0 10.10.1.101        "L2L VPN Tunnel between off site ASA Device and PIX"
ip route 10.10.8.0 255.255.255.0 10.10.1.101        "L2L VPN Tunnel between off site ASA Device and PIX"
14 Replies 14
Hello
if the 3560s upport PBR -that should do the trick
res
paul
Sent from Cisco Technical Support Android App
Kind Regards
Paul
Thank You for your responce.  I have heard of PBR and i believe this is the correct approach however i'm not sure if it is supported on the 3560 catalyst or even how to configure it.
james.doukas
You would need to do some policy based routing. There are a few ways you could do it. You could create a route-map to match the source subnet of vlan 11 and set the next-hop as the sonicwall gateway. This route-map could be applied to the outbound interface leading to the Internet firewalls. Traffic that doesn't meet the match requirement would follow the already defined gateway. Intervlan traffic should continue to route normally. Any traffic that matches the policy heading towards the PIX would have it's next hop set to the sonicwall.
Something like:
route-map internet-via-sonic permit 10
  match ip address (acl or prefix list)
  set ip next hop
route-map internet-via-sonic permit 20
interface vlan111
  ip policy route-map internet-via-sonic
ip prefix-list 10 permit 11.11.11.0/24
***However, this should be tested in a lab setup before trying to implement it into production to prevent any outages.***
Thank You James
i'm not that's heavily versed in Cisco commands.  I can create a VTP Domain and Vlans and set up Switchports  I'm not sure what to do with the match ip address (acl or prefix list) line you wrote
would you be able to give me a complete config?
The match ip address command needs something to match on. The acl or prefix list simply defines what to match. The prefix list below the other commands is an example.
So, you could create a prefix list like:
ip prefix-list send-to-sonic seq 10 permit 11.11.11.0/24
Then, you would use the name of the prefix list after the match statement:
match ip address prefix-list send-to-sonic
After that, you do the set ip next hop with the IP of the sonicwall.
After this, you apply the policy under the vlan interface that has the sonicwall. In your case, I believe its vlan111 according to your above text.
***Once again, test this first before trying in production***
i am doing the folowing
      set ip next 10.10.1.100
interface vlan111
I think my iOS is extremly old
Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(25)SEB1, RELEASE SOFTWARE (fc1)
Hmmm....the 3560 might be limited in how it can apply polices. Let me see if I can check this on a 3560 I have.
You might need to upgrade to IPServices from IPBase. I'll have to check the feature set.
It appears the route-map commands are in the release train you have (up to 50 at least) but they are unsupported according to Cisco. I'm still looking but for right now, it appears that the PBR might not be support on this version. Is this a 3560, 3560E or 3560X?
Unsupported Commands in Cisco IOS Release 12.2(50)SE
Unsupported Route Map Commands
match route-type for policy-based routing (PBR)
set as-path {tag | prepend as-path-string}
set automatic-tag
set dampening half-life reuse suppress max-suppress-time
set default interface interface-id [interface-id.....]
set interface interface-id [interface-id.....]
set ip default next-hop ip-address [ip-address.....]
set ip destination ip-address mask
set ip next-hop verify-availability
set ip precedence value
set ip qos-group
set metric-type internal
set origin
set tag tag-value
It is a WS-C3560G-24TS
Thank you for all your help so far
I have an 1800 series cisco router that i could use.  i can set the default route on the 3560 to go to the Router and then set it's default route to the PIX.  it should support PBR.  I was hoping to be able to do this without it on the network.  We had it in place when we had a Point to Point T1 in place a while ago.
In the show version, what is the Version Info for the IOS image? Should look similar.
Cisco IOS Software, C3560 Software (C3560-IPBASEK9-M), Version 12.2(50)SE3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Fri 29-Apr-05 22:25 by yenanh
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(25r)SE1, RELEASE SOFTWARE (fc)
VISSW1001 uptime is 12 weeks, 3 days, 10 hours, 21 minutes
System restarted at 10:38:05 UTC Tue Jul 9 2013
System image file is "flash:c3560-ipbase-mz.122-25.SEB1/c3560-ipbase-mz.122-25.SEB1.bin"
cisco WS-C3560G-24TS (PowerPC405) processor (revision C0) with 118784K/12280K bytes of memory.
Processor board ID FOC0922U0XG
Last reset from power-on
19 Virtual Ethernet interfaces
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
Was it purchases as the Standard or the Enhanced? Basically, WS-C3560G-24TS-S or -E? I'm not sure Cisco will support it if you put an image on it that wasn't part of the original model.
At this point, I would defer to Cisco as far as finding out if you can get the 3560 you have upgraded to IP Services the correct way. I'm not 100% sure about how you would upgrade and still get the proper supprt. However, to do PBR on the 3560 you have, you need IP Services according to Software Advisor.
