how to record session's configuration of users
mohammed hashim
hi,
for several cisco devices managed by several network engineers.
I want to record all the configurations done by each user and once he logout, cisco device send the configuration commands made as txt or any extension to external server (like TFTP or anything else).
there is a feature called "archive" in the global mode, but I do not see it suitable for this scenario !
can this task be done natively by cisco IOS, or it has to rely on 3rd party NMS solution ?
thanks,
johnd2310
Level 8
Level 8
It is easier to use TACACS or RADIUS server for this.
John
**Please rate posts you find helpful**
johnd2310
Level 8
Level 8
John
Thanks John,
I did not try any of them yet, I found a free TACACS+ software and will give a try
http://tacacs.net/
