SYS led is amber.
SteveHoyle
We are installing Cisco 2911 SEC/K9 for first time.  We plug in and the SYS led is amber.
5 Replies 5
glen.grant
  You will have to plug into the console port and look at the logs and see what is going on  and if it actually booted all the way up .
Thank-you Glen.  We have tried to plug in via RJ45 and USB 2.0.  The router is never detected.  The hyper terminal display remains blank.
Were you able to resolve this issue? I am having the same issue on my 2921 and it keeps rebooting after about 15 minutes. I've tried to replace the power supply and fans but that didn't work
willymaldonado1
I hope this helps.... you might also want to check this link......
http://www.cisco.com/en/US/docs/routers/access/interfaces/nm/hardware/installation/guide/eesm_hw.html
SYS
Green                 System is active
Blinking Green    System is booting up
Amber               System failed
Blinking Amber  Rommon failed
Best Regards....
Willy
nesstania1323
We have the same broblem with Router Cisco 2921. the SYS led is amber, We have tried to plug in via RJ45 and USB 2.0.  The router is never detected.  The hyper terminal display remains blank and the router reload every 20 minutes.
