How to redirect output of a particular router or switch command to a file
vinothlb1
How to redirect output of a particular router or switch command to a file..
for example, we can redirect dos command output like c:\dir > test.txt ..
In the same way i m not able to get o/p
in router or switch .. Pls help..
spremkumar
Level 9
Level 9
Hi Vinoth
One easy workaround to achieve is to make use hyperterm and capture the output of each command.
Else you can make use of any other term agent to achieve this..
regds
