How to remove module from running-config without reload switch?
kaiven_chu
Dears,
We just bought a new module  WS-X6816-10GE, and insert into Cat6509 slot 8 by test.
And now we move it back to slot 7, then show module, the new module appears on both slot 7 and 8.
Then I try to reload module, and show module again, It's come back to normal.
Mod Ports Card Type                              Model
  1  24  CEF720 24 port 1000mb SFP              WS-X6824-SFP
  3  48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6848-GE-TX
  5    5  Supervisor Engine 2T 10GE w/ CTS (Acti VS-SUP2T-10G
7  16  CEF720 16 port 10GE                    WS-X6816-10GE
But through show run commond, I still see the interface TenGigabitEthernet8/1 -16 in it.
And I tried to use "no interface te8/1" to remove the interface from running-config, but it doesn't work.
Is there any way for me to remove it from running-config without reboot switch?
Jon Marshall
What you should have done is use the module clear-config command before removing the module.  What you can try is to put the module back into slot 8 and then follow the instructions in this link -
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_example09186a008086ed2e.shtml#erase_config
Jon
weijun.duan
hi
hehe,First encounter,It does not affect your work on slot 7 .
Proposal ,wr-------copy start-configt  tftp------check it.
  try to :default int g8/1   。
Hi, Weijun
That config is stored in RAM, and everyting works fine.
If I backup it to tftp, and modify the config then copy it back to run, the running-config will be "merged" but not overwrited.
I afraid that I need to reboot the switch
Jon Marshall
Jon
Dear Jon.marshall,
OK, got it,
I'll try it, Thanks a lot.
