How to replace a failed redundant supervisor 2 on Catalyst 6509 running native mode.
andrea.meconi
Level 2
Level 2
Hi.
I'm looking for a doc to replace a failed sup2 on 6509 running native mode.
Thanks.
Reza Sharifi
Have a look at this doc.  There is a section for sup2 replacement.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/hardware/Module_Installation/Sup_Eng_Guide/supe_gd/03instal.html
Hi.
Many thanks for your help.
We have a chassis with two redundant supervisor 2 and one is now damaged.
Chassis is native and operates with RPR.
I'm looking for detailed procedure to replace the faulty supervisor.
I think I need to disable auto-sync, load the same IOS and finally enable the auto-sync again.
Is it right?
