04-13-2016 01:08 AM - edited 03-08-2019 05:20 AM
Hello All,
I am not able to do any ip nat inside and ip nat outside on any of the interfaces on my Nexus 6K. Please let me know if any feature need to be enable for nat configuration.
Solved! Go to Solution.
04-13-2016 06:46 AM
didnt say they were just layer 2 nexus are l2 and l3 depending on your modules like a 6500 switch but they dont do NAT , same as a layer 3 switch , you need an actual router to do NAT translations , i have 9ks,7ks,5ks and 2ks no NAT feature available on any of them
04-13-2016 01:18 AM
Nexus like catalyst do not support NAT , you will need a router for that function
04-13-2016 06:40 AM
Hi Mark,
Thanks for reply. It can run ospf, eigrp and bgp with repsective feature commands. I think its not a pure L2 device.
04-13-2016 06:46 AM
04-13-2016 07:18 AM
Sorry hold that looks like 6ks do support it but the others dont yet
Run show feature see if NAT is there , then enable it with conf t feature NAT
04-16-2016 03:43 AM
Hi Mark,
Thanks for assistance. I have searched on internet, upgraded image of 6k and show feature doesnt show anything for NAT. Seems like this platform doesnt support NAT although in configuration guide for 6K they show NAT configuration.
