how to restrict all except local subnet on a cisco switch
Abu Qasim
Dear all,
I need to restrict all my switch ports to only work with 192.168.0.0/24 network, even if a user on the network change the ip address of their pc, it shouldn't be worked... I have cisco 3560E 48-p switch.
Thanks.
Ah much simpler. Assuming you have clients connected to ports 1 to 46:
ip access-list standard LOCAL_NET01
  permit ip 192.168.0.0 0.0.0.255
int range gi1/0/1-46
  ip access-group LOCAL_NET01 in
cheers,
Seb.
8 Replies 8
Seb Rupik
Hi there,
You need to look at DHCP snooping combined with IP Source Guard
The DHCP snooping will build a database of valid DHCP leases, and the IP Source Guard will enure that only packets with a valid combination of source IP and MAC address are permitted to transmit on the selected switchports.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750e_3560e/software/release/15-0_1_se/configuration/guide/scg3750e/swdhcp82.html
cheers,
Seb.
Dear Seb.
I need to done it without dhcp,,,,
OK, you can still achieve this via a static binding, but you will need to know the switchport which each device is connected to. If the device moves to another switchport, IP Source Guard will deny its traffic:
The syntax is:
ip source binding mac-address vlan vlan-id ip-address interface type mod /port
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipaddr/command/ipaddr-cr-book/ipaddr-i4.html#wp3449769671
Just to clarify when you said "user on the network change the ip address of their pc", were you suggesting that if a user changes their address to another IP in the permitted 192.168.0.0/24 subnet the connection will still work?
If users are allowed to change their IP within 192.168.0.0/24, then a simple standard ACL will suffice.
cheers,
Seb.
let me give you some more details.
the switch should only work with the network address of 192.168.0.0/24, if another network address is used with any node/device, the switch should deny/stop the communication.
cheers,
Seb.
dear seb,
can you write me all steps..... :)
Hello
is this a layer 3 switch?
res
paul
Kind Regards
Paul
its layer 2 switch
