How to Restrict FTP traffic on cisco router by traffic shapping.
KR SHAH
Hi  all,
I need to implement Qos on cisco router. My main Aim is to restrict FTP traffic from external to internal. Please suggest How can i implement.   I had two ISP configure on interface & need to restrict on both interface. then How can I do it?
8 Replies 8
Julio E. Moisa
There are ways to block a port like 20/21 used for FTP
Example 1
access-list 100 deny tcp any any range 20 21
access-list 100 permit ip any any
interface g0/0
ip access-group 100 in
Example 2
access-list 100 permit  tcp any any range 20 21
class-map FTP
match access-group 100
    or
match protocol ftp
policy-map QOS
class FTP
drop
interface g0/0
service-policy input QOS
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Thanks for reply.
But i have still some query. such as
if i go for example 2
1. Should i need to create access-list 100 permit  tcp any any range 20 21 if I use
class-map FTP
match protocol ftp
_________________________________
2. policy-map QOS
   class FTP
   drop
My main aim to restrict BW for FTP traffic only. so as per my understand above config will drop FTP traffic. Correct me if i wrong?
3.  While On interface which command will work . i.e. service-policy input or service-policy output.
Because i need to restrict BW of FTP traffic from external to Internal.
4.In my scenario where to apply service-policy command i.e. on WAN interface or LAN interface.
5. what is the difference between service-policy input or service-policy output.?
 No, you can use ACL or Protocol command, now if you want to be more specific to avoid the traffic from a specific source I suggest ACL.
class-map FTP
match protocol ftp
2. policy-map QOS
   class FTP
   drop
My main aim to restrict BW for FTP traffic only. so as per my understand above config will drop FTP traffic. Correct me if i wrong? Yes, it will restrict the FTP traffic only, inbound or outboud how you are applying it. There is an implicit default-class you could see it through show policy-map interface <interface>
Because i need to restrict BW of FTP traffic from external to Internal.  It should be applied as input under the wan interfaces.
4.In my scenario where to apply service-policy command i.e. on WAN interface or LAN interface. WAN Interfaces.
5. what is the difference between service-policy input or service-policy output.? The direction, input is for incoming traffic from external to the router while output is for outgoing traffic from the router to external.
Thanks for such quick response. It clear almost all doubt except one.
class-map FTP
match protocol ftp
i just want to know if i configure Class- Map with match protocol instead of match access-group then it will work or not.
Again thanks for clear the concept.
You are welcome, yes, match protocol will work perfectly.
Okay I will try to config & see the result if it is working or not.
Thanks for solution.
You are welcome, please keep me posted of the results,
Have a great weekend.
Hi Julio,
I tried the same config but getting error while apply the command service-policy input. The error is "Weighted Fair Queueing feature not supported in input policy. Bandwidth command not allowed at parent level in input direction"Please suggest.
