How to see Signal strength of Cisco Access point | CISCO AP1242AG-T-K9
Haider Raza
Hi Team,
how i see the signal strength of cisco access point by GUI & CLI , kindly help in this regard.
Access point model number is : CISCO AP1242AG-T-K9
note : users are complaint for signal strength issue
5 Replies 5
Haider Raza
Hello Everyone ,
Kindly help in this regard ...!!!
Signal output max. is stated in decibels (db) on AP specs.
To check signal strength at a particular spot around the AP you can use any of the available apps for mobile phones.
HTH.
Sorry , i could not get your words....Please explain.
rasmus.elmholt
Level 7
Level 7
I cant rememeber but maybe show dot11 associations will show you the RSSI for the connected clients.
Julio E. Moisa
The suggestion is make a heat map studio, for example you could buy a tool like netspot tool.
https://www.netspotapp.com/best-wifi-heatmap-software.html
These tools will help to identifiy the signal provided by each access point on your facility.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
