How to see the duplex mode of an interface ?
chandra_rc16
Level 4
Level 4
The output of show interface fa0/0 is not showing the duplexing mode of that port. Need it very urgently.
Router1#show interfaces fastEthernet 0/0
FastEthernet0/0 is up, line protocol is up (connected)
  Hardware is Lance, address is 0001.96cb.297d (bia 0001.96cb.297d)
  Internet address is 10.11.12.1/24
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  ARP type: ARPA, ARP Timeout 04:00:00,
  Last input 00:00:08, output 00:00:05, output hang never
  Input queue: 0/75/0 (size/max/drops); Total output drops: 0
  Queueing strategy: fifo
  Output queue :0/40 (size/max)
     148 packets input, 6480 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     126 packets output, 5398 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 lost carrier, 0 no carrier
Thanks in advance.
Chandu
Regards, Chandu
11 Replies 11
Jon Marshall
Chandu
sh int status | include fa0/0
Jon
Jon,
I'm using PT. It wont support include command.
Chandu
Regards, Chandu
And even it doen't have status option :
switch0#show interfaces ?
  Ethernet         IEEE 802.3
  FastEthernet     FastEthernet IEEE 802.3
  GigabitEthernet  GigabitEthernet IEEE 802.3z
  Vlan             Catalyst Vlans
  etherchannel     Show interface etherchannel information
  switchport       Show interface switchport information
  trunk            Show interface trunk information
Chandu
Regards, Chandu
Your interface output is showing no collisions or later collisions so it's safe to say it is operating in full duplex mode.
Jon
Edit - just seen your last reply.
Jon
chandra_rc16
Level 4
Level 4
Jon, actually i configured it to be half-duplex.
That's the reason i want it to confirm with any show command.
Chandu
Regards, Chandu
chandra_rc16
Level 4
Level 4
Even again i configured it to be half duplex.
Router1(config)#interface fastEthernet 0/0
Router1(config-if)#duplex half
Router1(config-if)#end
Router1#
%SYS-5-CONFIG_I: Configured from console by console
But still the output is not showing the duplexing:
     0 packets input, 0 bytes, 0 no buffer
     0 packets output, 0 bytes, 0 underruns
Router1#
Chandu
Regards, Chandu
What is the other end of the link configured as ? If it is also half duplex then you should not see late collisions but you should still see some collisions.
Jon
chandra_rc16
Level 4
Level 4
Other end is also half-duplex, other end is a siwtch.
switch0#show cdp neighbors
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone
Device ID    Local Intrfce   Holdtme    Capability   Platform    Port ID
Router1      Fas 0/3          164            R       C2600       Fas 0/0
Truncated o/p for Fa0/3 on switch:
switch0#show interfaces fastEthernet 0/3
FastEthernet0/3 is up, line protocol is up (connected)
  Hardware is Lance, address is 00d0.ba12.5103 (bia 00d0.ba12.5103)
BW 100000 Kbit, DLY 1000 usec,
  Keepalive set (10 sec)
  Half-duplex, 100Mb/s
  input flow-control is off, output flow-control is off
Chandu
Regards, Chandu
Then you may well see some collisions at some stage in the interface statistics but not late collisions.
One other point to make. Remember that PT does not always emulate exaxtly what real switches and routers do.
Jon
1.  If the other end is half-duplex, then the local end has to be half duplex.  Your link won't go up if one end is half duplex and the other is full duplex.
2.  Your "PT" must be running an old cold.
