How to send VLAN Tags across Routers
joopdog11
I have two 1841 routers that are connected over a dedicated T1 line. I would like to be able to extend the vlan information on one network to the other. So basically I would like to be able to use a trunk link over the T1.
Is this possible?
Switch-----Router-----Router-------Switch
vlan1                  T1                 vlan2
vlan2                                      vlan5
vlan5
The T1 is our point to point connection across two cities.
How can I have vlan2 and vlan5 across both routers?
ROUTER - 1841 (CITY 1)
Joopdog-Cool#sh run
Building configuration...
Current configuration : 3283 bytes
version 12.4
hostname Joopdog-Cool
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 $1$uxQC$iXsyBK8
enable password joopdog
no aaa new-model
clock timezone EST -5
ip cef
no ip dhcp use vrf connected
ip dhcp pool Production-Cool
   network 192.168.10.0 255.255.255.0
   netbios-name-server 192.168.1.14 192.168.1.108
   dns-server 192.168.1.14 68.238.112.12
   default-router 192.168.10.10
   lease 0 1
ip domain name yourdomain.com
username joopdog privilege 15 secret 5 $1$3O2O$JvquiTZDacdI8NO4cIQ.g1
archive
log config
  hidekeys
interface FastEthernet0/0
description LAN connection for PC's. 1841 Router.
ip address 192.168.1.10 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
description Ethernet virtual private line connection - NY side.
ip address 192.168.98.1 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/1/0
description LifeSize Video VLAN 5
switchport access vlan 5
interface FastEthernet0/1/1
description VLAN TRUNKs
switchport mode trunk
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface Serial0/0/0
description T1 connection - NY side.
ip address 192.168.254.9 255.255.255.252
encapsulation ppp
no ip mroute-cache
no fair-queue
interface Vlan1
no ip address
interface Vlan5
ip address 192.168.5.10 255.255.255.0
interface Vlan10
description Production-Cool
ip address 192.168.10.10 255.255.255.0
interface Vlan11
description Voice-Cool
ip address 192.168.11.11 255.255.255.0
interface Vlan99
description Point-to-Point
ip address 192.168.99.1 255.255.255.252
router eigrp 7
network 192.168.1.0
network 192.168.3.0
network 192.168.11.0
network 192.168.254.0
no auto-summary
ip default-gateway 192.168.1.9
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.1.9
ip route 10.1.7.0 255.255.255.0 192.168.1.7
ip route 10.1.9.0 255.255.255.0 192.168.1.9
ip route 10.3.7.0 255.255.255.0 192.168.3.7
ip route 192.168.2.0 255.255.255.0 192.168.1.6 permanent
ip route 192.168.11.0 255.255.255.0 192.168.1.6 permanent
ip route 192.168.199.0 255.255.255.0 192.168.98.2
no ip http server
ip http access-class 23
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
map-class frame-relay v384k
frame-relay cir 384000
frame-relay bc 3840
frame-relay be 0
frame-relay mincir 384000
frame-relay fair-queue
map-class frame-relay v512k
frame-relay cir 512000
frame-relay bc 5120
frame-relay be 0
frame-relay mincir 512000
map-class frame-relay v768k
frame-relay cir 768000
access-list 23 permit 192.168.0.0 0.0.255.255
access-list 23 permit 10.0.1.0 0.0.0.255
access-list 102 permit udp any any eq rip
control-plane
line con 0
password cisco
login
line aux 0
line vty 0 4
access-class 23 in
exec-timeout 60 0
privilege level 15
password cisco
logging synchronous
login local
transport input telnet
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
Joopdog-Cool#
Reza Sharifi
Have a look at this document for example:  It is called Transparent bridging
http://www.cisco.com/en/US/tech/tk331/tk660/technologies_tech_note09186a0080094471.shtml
You can intead keep the vlans diiferent in each location and use the routers to route your vlans.
Reza
Is this the way?
lipos
EoMPLS - check daunderground.net for details. It's easy and scales well.
