How to connect three routers directly in subinterface of LAN
majed.balsharaf
I need some help how we can make direct connect to two routers with same subinterface in LAN.
Example:
R1 interface f0/0.12 is connected to R2
and
R1 f0/0.13 is connected to R3
Reza Sharifi
Majed,
In your diagram you have fa0/0 physically connected to both routers.  You cannot connect fa0/0 physically to one router and connect the same interface to a different router.
You can however have multiple sub-interface between 2 routers
on r1
example:
fa0/0.1
ip address 10.10.10.1/24
fa0/0.2
ip address 10.10.11.1/24
r2
fa0/0.1
ip address 10.10.10.2/24
fa0/0.2
ip address 10.10.11.2/24
with enca dot.1q on all sub-interfaces.
Reza
Reza Sharifi
Majed,
on r1
example:
fa0/0.1
fa0/0.2
r2
fa0/0.1
fa0/0.2
Reza
