How to separate VLANs in a switch
Peter.D.Brown
Hi there, I've got a 6500 switch which has 6 VLANs on it (1,2,3,4,5,6). All of the VLANs have IP addresses for routing. How would I be able to make it so that VLANs 1,2 and 3 can route to each other, and VLANs 4,5 and 6 can route to each other but the 2 groups of 3 VLANs can't see each other (i.e. so 1,2,3 can't see (or pass traffic between) 4,5,6).
Any advice appreciated, thanks
Pete.
Jon Marshall
Pete
You could just use access-lists on the vlan interfaces to keep the traffic segregated but if you wanted separate routing tables then you need to look into vrf-lite which is supported on the 6500.
Jon
I stand corrected, but I think the solution is the combination on the above 2 replies.
PVLAN will take care of L2 cross talk, where as ACL takes care of L3.
I have using PVLAN + ACLs at edge 4500 to protect customers from each other and network customers.
Sam
Peter.D.Brown
Thanks for all the replies guys. They've given me some good ideas to think about so now I'll have a bit of a read round.
