How to set up Default Gateway on computers?
informatyka
GDL 1 and GDL 2 and MEX 01 are computers.
It shows that I do not have the Default Gateway set on them.
What is it and how do I set it up?
I am also sending photos to show what it looks like for me.
marce1000
 - You better have a DHCP server in place , which can distribute the complete 'ip environment' for the computers including the default gateway.
 M.
post your zipped Packet Tracer poject (.pkt) file...
zaralarsnor
Two ways:
Manually set it, for example in Windows you go to the network adapter settings, enter the IP address, subnet mask and gateway address
Second way is to use DHCP. This is an automated process, the windows machine will request the IP address details from the DHCP server.
When you do ipconfig, you won’t see 0.0.0.0 for the gateway, it’ll be the actual address of the router <a href="https://networthplanet.com/"> net worth planet </a>
