C3750 - trying to get POE to work
i have a c3750
i am able to access Console
i dont know how to program it to allow POE to work
basically if i go
MODEM (ethernet) COMPUTER - works
if i go
MODEM (ethernet) SWITCH (ethernet) COMPUTER - does not work
i need to activate the POE ports on the back
also i need to set password/login as i plan to use there for my camera system
8 Replies 8
balaji.bandi
what is the Full Model  of the device,
post below information to help further :
show version
show power inline
show inventory
BB
Seb Rupik
Hi there,
What model 3750 are you using? What is the output of sh inv on the device?
Typically only models with a P or U suffixed after the port number support POE.
Based on my understanding of your message, 'POE pass through' is not supported.
cheers,
Seb.
Leo Laohoo
Only if the model supports PoE.
WS-C3750X-48P-L V02 is the product id
is that what your after
What do you mean "on the back"?
The ports at the back of a 3750X is for console and a Management Port.  The Management Port does not support PoE.
these are not POE ports?
maybe i bought the wrong thing here, i thought this could be used as a POE SWITCH
so i can run the IP cameras directly to my PC as my current NVR only supports swann cameras and i got bunch from different supplier i want to use
What is the exact model of the switch?
