how to set up fabric extender
robertkwild
hi all,
we have nexus 7000's with FEX switches but im planning to buy more FEX's on ebay, in particular this one
N2K-C2248TP-1GE
just wondering how you set them up as someone said all you do is create a PO for it and thats it?
thanks,
rob
balaji.bandi
Is the nexus in vPC
check the matrix :
https://www.cisco.com/c/dam/en/us/td/docs/switches/datacenter/nexus7000/sw/matrix/technical/reference/Module_Comparison_Matrix.pdf
you looking FEX to to dual homed or single homed ?
Single home simple config on nexus 7K
Nexus7K01# configure terminal
Nexus7K01(config)# interface port-channel 100
Nexus7K01(config-if)# switchport mode fex-fabric
Nexus7K01(config-if)# fex associate 100
Nexus7K01(config-if)# exit
Nexus7K01(config)# interface ethernet 1/28
Nexus7K01(config-if)# channel-group 100
Nexus7K01(config)# interface ethernet 1/29
if you have dual home
apply the same config on other nexus
and apply below config on both the switches and connect the cables and check.
Nexus7K01(config)# vpc 100
BB
7 Replies 7
Mark Elsen
 - FYI  : https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus2000/sw/configuration/guide/rel_521/Configuring_the_Cisco_Nexus_2000_Series_Fabric_Extender_rel_5_2_chapter2.html#task_90B3DE7857AE4B008933DB885323D140
     Yet , I myself would never buy such datacenter critical  equipment on ebay , only from  Cisco reseller ,
 M,
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
balaji.bandi
Is the nexus in vPC
check the matrix :
BB
robertkwild
yeah the switches in vPC but tbh im just going to plug the FEX's in one switch as plugging in both will require more sfp modules, more fiber cables and take up more valuable 10gig ports on the nexus 7000 blades
but if i did do dual home would i need to mirror the same ports so if i were to plug it in
SW1 eth1/1,eth2/1
would i need to plug it in the same ports on SW2 or can one be plugged in 2/2 instead of 2/1
also i have read if you dual home your FEX's you can only use half the number of FEX switches
robertkwild
instead of doing this
switch# configure terminal
switch(config)# interface port-channel 4
switch(config-if)# switchport mode fex-fabric
switch(config-if)# fex associate 101
switch(config-if)# exit
switch(config)# interface ethernet 1/28
switch(config-if)# channel-group 4
switch(config)# interface ethernet 1/29
switch(config)# interface ethernet 1/30
switch(config)# interface ethernet 1/31
cant you just do
switch(config)# interface port-channel 101
switch(config)# interface ethernet 1/28-31
switch(config-if)# channel-group 101
worked a treat, all i did was this
switch(config-if)# fex associate 120
switch(config-if)# channel-group 120
switch(config-if)#no shut
Sure that also works - it all depends on the requirement. single home vs dual home - both the option available - we need to choose which is the right choice.
BB
