How to set up SPAN for a vlan Interface
atef yamin
I am trying to capture traffic for a particular VLAN. I tried to do the following:
Torsaa-mls1(config)#monitor session 2 source interface vl
Torsaa-mls1(config)#monitor session 2 source interface vlan1
% Invalid input detected at '^' marker.
So VLAN are not supported. Is there any other way to accomplish this?
The 3560 does support vlans as the source. I think it may be your configuration ie. -
don't use the interface and vlan commands together. The command syntax is -
"monitor session source vlan "
Jon
Jon Marshall
It might help if you told us the switch model and IOS version
Jon
There you go, SORRY!
Cisco IOS Software, C3560E Software (C3560E-UNIVERSALK9-M), Version 12.2(50)SE2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 15-May-09 22:11 by nachen
Image text-base: 0x00003000, data-base: 0x02400000
ROM: Bootstrap program is C3560E boot loader
BOOTLDR: C3560E Boot Loader (C3560E-HBOOT-M) Version 12.2(44r)SE3, RELEASE SOFTWARE (fc3)
Torsaa-mls1 uptime is 8 weeks, 4 days, 16 hours, 26 minutes
System image file is "flash:c3560e-universalk9-mz.122-50.SE2/c3560e-universalk9-mz.122-50.SE2.bin"
License Level: ipservices
License Type: Permanent
Next reload license Level: ipservices
cisco WS-C3560E-48TD (PowerPC405) processor (revision L0) with 122880K/8184K bytes of memory.
Processor board ID FDO1447Y1JL
Last reset from power-on
16 Virtual Ethernet interfaces
1 FastEthernet interface
52 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : E0:5F:B9:3C:9E:00
Motherboard assembly number     : 73-11179-14
Motherboard serial number       : FDO14480AXG
Model revision number           : L0
Motherboard revision number     : A0
Model number                    : WS-C3560E-48TD-E
Daughterboard assembly number   : 800-29737-01
Daughterboard serial number     : FDO14470SUG
System serial number            : FDO1447Y1JL
Top Assembly Part Number        : 800-28930-04
Top Assembly Revision Number    : B0
Version ID                      : V05
CLEI Code Number                : COMCJ00ARB
Hardware Board Revision Number  : 0x00
Switch Ports Model              SW Version            SW Image
*    1 54    WS-C3560E-48TD     12.2(50)SE2           C3560E-UNIVERSALK9-M
Jon
Thanks it worked, appreciat it.
