how to setup dns over frame-relay
dannan lin
hi:
i have a simple frame-relay setup as shown in the picture below
each private address is nat translated. i can visit the server by using its global ip address but i could not use its named address.
all devices are linked ok,
the PC1 side router config are:
ip dhcp pool field_office
network 192.168.1.0 255.255.255.0
default-router 192.168.1.254
dns-server10.10.10.10
ip name-server 10.10.10.10
what else should i do to , it seems like pc1 could not resolve dns. shall i place another dns ????
any helps?
best regards.
cadet alain
can you contact pc2 by name ?
Regards.
Alain
cadet alain
Regards.
Alain
thanks cadet, i have resoloved the problem, it seems i mis-configured somthing on the NAT.
