Showing results forĀ
Search instead forĀ
Did you mean:Ā
how to setup same console password in 12 cisco switch 2950
prashantrecon
My requirement is that I want to set same console  password in 12 switch instantly...
All the 12 switch are connected to a cisco 6500 L3 switch..
So how can i do that......
i have cisco acs 4.1...
can i do that by cisco acs 4.1 if not please tell me an software or command ....
Prashant
cadet alain
which terminal emulator are you using?
Alain.
hyper terminal
I don't think you can do this with Hyperterminal but you can do it natively with SecureCRT with the chat windows and there are plugins for Putty to do this also.
But You'll have to use a terminal server to achieve this with the above tools.
Regards.
Alain
